270
Set blank Description on Summary Row
GroupByHhere is a screenshot when i drag a column to group by Trans Type.
Usually, when rows are grouped, the summary row will say something like "Trans Type : 3 items" or something like that.
But i want to hide that default description because i have written my own ICustomSummaryCalculator for each row.
I tried to use this, but it still leave the empty area in blue summary row (see screenshot).
     ultraGridSummary.DisplayLayout.Override.GroupByRowDescriptionMask = " ";
There description (empty areas above the summary cells in the blue summary row)
I tried to set GroupBySummaryDisplayStyle, it only provide option GroupBySummaryDisplayStyle.SummaryCells which show summary on the same level if it does not intersect with the summary row description.
I also tried to use the InitializeGroupByRow event on the grid, and set the description to blank, but none works.
Do you know of a way to get rid of that Description area so that it won't leave empty space?  Thanx
Parents
No Data
Reply
  • 705
    I managed to solve it by adding a "blank" column:
                UltraGridColumn blankColumn = _grid1.DisplayLayout.Bands[0].Columns[0];
                // BLANK COLUMN ENSURES THAT SUMMARY ONLY EVER OCCUPIES ONE LINE
                blankColumn.Header.VisiblePosition = 0;
                // In order to resize any column (in this case 'Blank') we need to temporarily
                // ensure it's visible before setting the width and restoring its visible property
                blankColumn.Hidden = false;
                blankColumn.Width = 0; // NOTE: it will set to the default minimum which appears to be 8
                blankColumn.Hidden = true;
                blankColumn.LockedWidth = true;
                blankColumn.AllowGroupBy = DefaultableBoolean.False;
                blankColumn.AllowRowFiltering = DefaultableBoolean.False;
                blankColumn.AllowRowSummaries = AllowRowSummaries.False;
                blankColumn.Header.Caption = string.Empty;
Children
No Data
