270
Add editable cell in Summary GroupBy row??!
I have a UltraWinGrid and some of the columns have the EditorControl override to be the UltraCalendar object so that user can use to select date values for a cell.
When i drag a column to the GroupByBox at the top, the summary row (UltraGridGroupByRow) show the summary values of each column defined by my ICustomSummaryCalculator.
Is there a way to make this summary row editable by embedding an EditorControl into this UltraGridGroupByRow???
What i want to achieve is that user should be able to click on the summary row and select a date from an UltraCalendar, then i will capture the event and populate all childRows to have the same value.
I have been looking for examples on how this could be done.
Please advise.  Thanx.
  • 48586
    I just wanted to know if you were able to solve your issue based on my suggestions or you still need help? Just let me know.
    Thank you.
  • 48586
    Hello ,
    One possible way to achieve your goal is to use creation filter in order to put UltraCalendarCombo in GroupByRow. I have demonstrated this approach in the attached sample.
    WinGridGroupByRowCalendar.zip
