45
Can't access SelectionStart unless the Editor is in edit mode.
Any idea why this exception should occur on a gridLines.PerformAction(UltraGridAction.EnterEditMode) call?
Type: System.InvalidOperationException
Message: Can't access SelectionStart unless the Editor is in edit mode.
Source: Infragistics2.Win.v8.2
Target Method: [Infragistics2.Win.v8.2]Infragistics.Win.EmbeddableEditorBase::get_SelectionStart()
Call Stack:
   at Infragistics.Win.EmbeddableEditorBase.get_SelectionStart()
   at Infragistics.Win.EmbeddableEditorBase.set_SelectionStart(Int32 value)
   at Infragistics.Win.UltraWinGrid.UltraGridCell.SelectAll()
   at Infragistics.Win.UltraWinGrid.UltraGridCell.OnAfterCellEnterEditMode()
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.OnEditorAfterEnterEditMode(Object sender, EventArgs e)
   at Infragistics.Win.EmbeddableEditorBase.OnAfterEnterEditMode()
   at Infragistics.Win.EditorWithText.OnAfterEnterEditMode()
   at Infragistics.Win.EmbeddableEditorBase.EnterEditMode(EmbeddableUIElementBase embeddableElement)
   at Infragistics.Win.UltraWinGrid.UltraGridCell.EnterEditorIntoEditMode(Boolean byMouse)
   at Infragistics.Win.UltraWinGrid.UltraGridCell.EnterEditMode(Boolean byMouse, Boolean showingDropDown)
   at Infragistics.Win.UltraWinGrid.UltraGridCell.EnterEditMode(Boolean byMouse)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.PerformAction(UltraGridAction actionCode, Boolean shiftKeyDown, Boolean ctlKeyDown)
   at Infragistics.Win.UltraWinGrid.UltraGrid.PerformAction(UltraGridAction actionCode, Boolean shift, Boolean control)
   at Infragistics.Win.UltraWinGrid.UltraGrid.PerformAction(UltraGridAction actionCode)
   at DandK.Vision.Client.PlugIn.POSTicket.TicketForm.ActivateGrid() in S:\Vision\Client\PlugIn\POSTicket\POSTicketForm.cs:line 5094
