440
Images In Documents
Hi
I have been reading the documantation on how to add images to an Infragistics.Document - seems basically straight forwards, but...
How do I read the image from a file (or maybe from an UltraPictureBox.Image), resize in memory, and place on the document?
Thanks for your help
  • 37774
    Verified Answer
    You could read in the image as a bitmap (the constructor has an overload that takes a file name), then draw that image into a new Bitmap:
    public Bitmap ResizeBitmap(Bitmap b, int nWidth, int nHeight)
        Bitmap result = new Bitmap(nWidth, nHeight);
        using (Graphics g = Graphics.FromImage((Image)result))
            g.DrawImage(b, 0, 0, nWidth, nHeight);
        return result;
    You would then add it to the document through whichever element you're using, such as:
    section.AddImage(new Infragistics.Documents.Graphics.Image(bmp));
    -Matt
