945
SubObjectPropChanged event
I have a main menu toolbar, and I want to be notified when status of the menu items are changed.
I tried to subscribe to SubObjectPropChanged event, but it did not get notified when menu items change to Enabled to Disabled.
Is this the correct event that I should listen to?
Thanks.
  • 44743
    You can hook the PropertyChanged event on the UltraToolbarsManager with code similar to this:
    private void ultraToolbarsManager1_PropertyChanged( object sender, Infragistics.Win.PropertyChangedEventArgs e )
     PropChangeInfo changeInfo = e.ChangeInfo.FindTrigger( null );
     if ( changeInfo.PropId is PropertyIds && (PropertyIds)changeInfo.PropId == PropertyIds.Enabled )
      SharedProps sharedProps = changeInfo.Source as SharedProps;
      if ( sharedProps != null )
       ToolBase toolWithEnabledStateChange = sharedProps.RootTool;
       // Perform logic with tool whose enabled state has changed.
