220
retaining cell focus in ultrawingrid
I have a validation in place for a cell in ultrawingrid that user can not leave that cell as blank. The problem is - the grid shows the validation message after the user leaves that cell as blank but the focus goes to another cell where user clicks. is there any way I can retain the focus on the cell in question?
I am showing the validation message in BeforeCellUpdate event. Following is my code -
If TypeOf e.NewValue Is System.DBNull Then
Dim message As String = "The value for the cell can not be left blank"
MessageBox.Show(message, "Invalid value", MessageBoxButtons.OK, MessageBoxIcon.Error)
e.Cancel = True
'ugCanopySpecies.Focus()
e.Cell.Activate()
ugCanopySpecies.PerformAction(UltraGridAction.EnterEditMode)
'e.Cell.SelectAll()
Return
End If
and changing the value of rowupdatecancelaction does not make any difference.
thanks,
Mandeep.
  • 37774
    If you want to prevent the user from leaving the cell, you should cancel the BeforeExitEditMode event instead of BeforeCellUpdate.
    -Matt
