400
Columns bound to parent entities
Hi!
I have an ultragrid with one band, bound to a list of Entity Framework entities. Lets say its bound to a list of Customer entities. Customer has a property called Country of type Country (just another Entity Framework entity). I want to display in my ultragrid a column with the name of the Country, without creating a view of my data (in database or EF level). To put it differently, I want to bound an ultragrid column to Customer.Country.Name property.
Is this possible?
  • 45049
    Verified Answer
    If you don't want to create a view of your data, then you need to use an unbound column in this scenario.  You can use the InitializeRow event to set the value from the data source to the grid.  You'll need to also use other events (such as AfterRowUpdate) to process any updates from the grid back to the data source.
