255
re-group re-sort when drop down value changes
I have a column in a wingrid which has a drop down list. This column is also being grouped on. When the user selects a new value from the drop down I would like the row to appear in the appropriate group based on the value. I.e. It might look like to start:
Groupd by Status
(+)Active
-Row 1 Status Active
(+)Inactive
-Row 2 Statis Inactive
 If user changes status in row 1 to Inactive it should now look like this:
(+)Inactive
-Row 1 Status Inactive
I have tried to simulate this by putting some code in AfterCellUpdate:
 this.ultraGrid.DisplayLayout.Bands[0].SortedColumns.RefreshSort(true);
This has an interesting affect. When the user selects the new value this is what it looks like:
(+)Inactive
(+)Inactive
 It creates two groupings with the same value. I've checked and the grouped by values are exactly the same. If you drag the group by column out of the group by box and then drag it back in, they are still grouped in seperate headers with the same values.
Is there an easy and proper way to do this?
thanks!
James
