I am trying to use DateTimeEditor as the editor for a column in Infragistics UltraWinGrids. I am having hard time to apply format to the display. I am wondering whether anybody can help me.
If all you want to do is change the format, then you should set the MaskInput property of the column to something like "yyyy/mm/dd". Format is for non-edit mode and mask is for edit mode. Note that you don't need any data filter for this.
Sandip
