145
Setup UltraWinGrid for Runtime Data Source
 I am new to Infragistics.  I am attempting to use the gird with a runtime data source.  I followed KB06702 and I have a grid with the data. First I didn't include two of the returned fields of the data source in the schema but they were appended to the grid.  I am not sure if this is a expected behavior.
I wanted to format the columns in the grid designer.  I setup a mask for a phone number and selected one column as hidden.  The masked worked fine but the hidden column still shows up?
If this is expected how do I hide a column in code (VB)?
Does anyone know of a document that outlines what does and doesn't work If some column properties work and other don't when setting a schema against a runtime data source?
Finally,  Does anyone know of a document/code sample that clearly shows how to manually setup a grid with column types and colum properties in VB.  I looked at a few things but I didn't see a complete example.  I am probably just missing it.
Adam
