585
showing tooltip for ultralistview headers
Hi All,
How can i show a tooltip for ultralistview headers while in detailed view?
Thanks and Regards
Manikandan
  • 69832
    The following code sample demonstrates how to show a tooltip for an UltraListViewColumnHeaderUIElement using the UltraToolTipManager:
    private UltraToolTipManager toolTipManager = null;
    private UltraToolTipInfo toolTipInfo = null;
    private void Form1_Load(object sender, EventArgs e)
        this.listView.MainColumn.Text = "Name";
        this.listView.View = UltraListViewStyle.Details;
        int itemCount = 100;
        UltraListViewItem[ items = new UltraListViewItem[itemCount];
        for ( int i = 0; i < itemCount; i ++ )
            itemsIdea = new UltraListViewItem();
            itemsIdea.Value = string.Format("Item {0}", i);
        this.listView.Items.AddRange( items );
        this.listView.MouseEnterElement += new UIElementEventHandler(this.listView_MouseEnterElement);
        this.listView.MouseLeaveElement += new UIElementEventHandler(this.listView_MouseLeaveElement);
    private void listView_MouseEnterElement(object sender, UIElementEventArgs e)
        UltraListView listView = sender as UltraListView;
        //  Create the UltraToolTipInfo if it is null
        if ( this.toolTipInfo == null )
            this.toolTipInfo = new UltraToolTipInfo();
            this.toolTipInfo.ToolTipTitle = "UltraListView";
        //  Create the UltraToolTipManager if it is null, and associate
        //  it with the UltraListView and this form
        if ( this.toolTipManager == null )
            this.toolTipManager = new UltraToolTipManager(this.components);
            this.toolTipManager.ContainingControl = this;
            this.toolTipManager.SetUltraToolTip( listView, this.toolTipInfo );
        //  If the cursor is positioned over an UltraListViewColumnHeaderUIElement...
        UltraListViewColumnHeaderUIElement headerElement = e.Element as UltraListViewColumnHeaderUIElement;
        if ( headerElement != null )
            //  Get the column; check for null because it will be if this is
            //  the "dummy" column header, i.e., the one that is shown when
            //  the actual columns don't fill the entire width of the control.
            UltraListViewColumnBase column = headerElement.Column;
            if ( column != null )
                //  Set the ToolTipText and show the tooltip
                this.toolTipInfo.ToolTipText = column.TextResolved;
                Rectangle toolTipRect = listView.RectangleToScreen(headerElement.Rect);
                Point toolTipLocation = new Point( toolTipRect.Right, toolTipRect.Top );
                this.toolTipManager.ShowToolTip( this.listView, toolTipLocation );
    private void listView_MouseLeaveElement(object sender, UIElementEventArgs e)
        //  Hide the tooltip when the cursor exits the bounds of an UltraListViewColumnHeaderUIElement
        if ( e.Element is UltraListViewColumnHeaderUIElement &&
             this.toolTipManager != null )
            this.toolTipManager.HideToolTip();
