290
WinGrid column image from oracle
I'm using a Wingrid 8.2and I've bound my grid to a dataset coming from a oracle 10 database. One of the columns is a byte-array containing jpeg-data. I use the following code in InitializeLayout;
ugrdThis.DisplayLayout.Bands[0].Columns["MyImageCol"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.Image;
ugrdThis.DisplayLayout.Bands[0].Columns["MyImageCol"].Style.Editor = new Infragistics.Win.EmbeddableImageRenderer();
After that the cells in MyImageCol-column are showing the string "System.Byte[", thats it.
What's remarkable too: If I debug the column after codeline above, the Editor-property of the column will display the exception:
"EmbeddableImageRenderer does not support editing."
over the "Value"-property.
What's wrong?
Thanks, Alex
