Hey Guys, me yet again.
I have my appointments storred in a table called "ReservationTable". I fill a datatable with all these entries and then bind the UltraCaladerInfo to my UltraDayView. This all works perfect.
My new problem is that i have a few extra fields in the table as well, one of which is status (relates to the status of the reservation).
By default when a reservation is added it goes in with status of 0 (unconfirmed) and a appointment backcolor of red. When i mark the appointment as confirmed i change the color to green and update the status to 1. this all works fine as well.
My problem is that a change to the status can be made via another program as well, which will update the status of this appointment to 1, but i do not know how to update the backcolor. I know it is stored in "AllProperties" but how do i access the backcolor property
Thanks for any help
You should be able to handle the ListChanged event of the binding through which you access the appointment data, and set the Appointment.Appearance.BackColor property when a change is made to the status field.
