685
hierarchy grid update-add-delete
I keep getting Sql.Client.SqlException  Insert statement conflicted withy FOREIGN KEY constrainst ........
But I have broken it all up
level 1   add ; level2 add ; level3 add
level1 modified ; level2 modified ; level3 modified
level3 delete ; level2 delete ; level1 delete
using statements like
iret = this.Level1UpdateQryTableAdapter.Update(clientTreeData.Level1.Select("", "", DataViewRowState.Added));
I have tried doing slightly different  e.g.
this.clientTreeData.Level1UpdateQry.Clear();
this.clientTreeData.Level1UpdateQry.Merge(this.clientTreeData.Level1);
iret = this.Level1UpdateQryTableAdapter.Update(clientTreeData.Level1UpdateQry.Select("", "", DataViewRowState.Added));
I am wondering if I ought to preserve rows early on into arrays to later put into tables - but why?  e.g.
DataRow[ drarrayA = clientTreeData.Level1UpdateQry.Select("", "", DataViewRowState.Added );
And I am flushing out before each update  e.g.
So what is the trick , how do you ADD , MODIFY and DELETE three tables with a relationship?
I need the relationship in the XSD , so the grid is drilldown. There is little option to change enforcement rules, that I can see.
I can supply an example against Northwind, perhaps that is the best way to go. ???
  • 469350
    I'm having a hard time understanding the issue. This does not appear to be related to the Infragistics controls, it looks like you are hacing trouble writing changes from a DataSet back to the database. The grid never deals with the database, only the local data source. So you might have more luck posting on a Microsoft or more general DotNet forum.
