287
need to connect the ultraCalendarInfo to sybase
 we are using sybase as the database in our windows application...
now we have to perform ADD/Update/delete on appointments/Owners/Notes and it is required to store these objects in database, please suggest the best way of achieving this....
also please suggest some link for the c# code help to perform these Add/Update/Delete on appointments/Owners/Notes...
One more quick question - I got some code @ http://help.infragistics.com/Help/NetAdvantage/NET/2007.3/CLR2.0/html/Infragistics2.Win.UltraWinSchedule.v7.3~Infragistics.Win.UltraWinSchedule.OwnersDataBinding.html
but not sure what is the "this.scheduleData" representing.... And wat is significance of DataMember in that code and is it required to assign some value to it ??? - As we are already assigning DataSource, is that not enough...
 --Sumit
  • 69832
    The proprietary nature of the database you are using is not relevant to the WInSchedule data binding layer; it only communicates with an IBindingList interface implementor. Typically one uses a BindingSource, OleDb, etc. to create a DataSet, then sets the DataSource/DataMember properties on the UltraCalendarInfo.DataBindingForAppointments. I think you need to get the Sybase .NET Data Provider, which provides a communication layer between the database and the .NET runtime.
    "this.scheduleData", in the context of that code sample, is an instance of the System.Data.DataSet class.
