165
How can I put separators between ValueListItems in a combobox?
The subject pretty much says it all ... I'd like to put separators between ValueListItems in a combobox, as a way of grouping like items.
Any suggestions on how I can go about this?  Is there an example posted anywhere?
 Thanks!
  • 69832
    Our ValueList does not currently support this; if you like you can submit a feature request. It would be possible to hack this out using the IUIElementCreationFilter interface (insert simple elements that draw a horizontal line between the items) except that the metrics calculation routines won't know about it, so the last item would not be fully visible.
