how do I do to, while having a inbox in the MDI parent to pass its definitions to the children?I've tried to, by code, add a to each form on it's opening, but it doesn't work
Create a base form for the child MDI form.
Create on this form a inboxcontrolstyler
I'm afraid I do not understand your question. You probably need to place an InboxControlStyler on each form in your application. You can't use the same one for multiple forms as far as I know.
