I was binding my tree to a .Net dataset with tablenames and relationships - under this design the tablename was assigned as the bandname automatically.
The design has changed and I am now building the tree nodes manually, is there a way to set the BandName under this design. It is useful for setting contextual right click menus depending on the tree node level.
Tag Property worked great - thx!
I'm pretty sure that BandName is not settable. You could use the Tag property on the node, instead.
