205
grid groupby rows color
Hi guys! how can i customize the colors of groupby rows? i can get some of it thru DisplayLayout.Override.GroupByRowAppearance, but how can i change selected appearance? also, is it possible not to color the vertical spacing strip on the left in the color of groupby rows? thanx! M.
  • 469350
    It looks like the selected appearance is controlled by the SelectedRowAppearance on the Override. This applies to both data rows and groupby rows. There does not appear to be any way to distinguish between the two in the grid's object model. Maybe you can do that using AppStylist, or if not, you could always use a Drawfilter as a last resort.
    There's no property for this, but you can do it using a DrawFilter. I thought there was an example of this around somewhere, but I don't see it on the KB.
