Hello !
I have a UltraWinGrid that has a column with
on the Grid_InitializeRow event
I have set style as Infragistics.Win.UltraWinGrid.ColumnStyle.Color
and also able to set the right color for every row.
the problem is that it shows the rgb value, like the picture shown here.
How can i hide that ? I also want to allow user to change these color. I do not want even name of color.
I am very much new to Infragistics code. Any smaple code with explanation will help me lot.
hey.
I had the same issue.
It can be done by setting initialily:
Columns["ColorStyleColum"].CellAppearance.ForeColor = Color.Transparent;
then hook into the InitializeRow event and set ... e.Row.Cells["ColorStyleColum"].SelectedAppearance.ForeColor = Color.Transparent;
sadly i coulnd find anything like
Columns["ColorStyleColum"].SelectedCellAppearance ; (
be warned this more a hack than a solution the grid could very well be in a state that i overlooked, and the text will be shown again.
anyway ... hope it helps
regards
There is currently no way to hide the text. At least, no reasonably easy way. You might be able to do it using a CreationFilter or a DrawFilter.
You should Submit a feature request to Infragistics
