880
Refreshing the ribbon's default serialization key
I am serializing the state of my ribbon control on my ultraToolbarsManager.  To do this, under Serialization I am checking Save Settings.  Everything works fine until I make a change to the control at design time.  When I run the project it loads the old serialized version of the ribbon.  Okay, I can see that.  It isn't even trying to load my new ribbon because it things I want it to load serialized version.
I uncheck the Save Settings box and run the reprot, everything works as  expteed.  I see my new ribbion.  I check the box again.  Run the project and we are back to the same old serialized ribbon.  The only way I can get this to update it so change the Settings Key to a different name so it rebuilds the cache under the new key.  I realize this is a cludge and very unclean, but it works until I can find the "Refrsh cache" type option.
 Can anyone tell me how to reset my cached ribbion without creating a different key for every update?
 Thanks.
