535
Infragistics.Documents to UltraPrintPreviewDialog displays text as fuzzy gray or not sharp
v8.3 Win. The preview of the report displays text in fuzzy dark gray like text on disabled controls. When this report is saved as a PDF file the text appears normal in a PDF Viewer, that is, sharp and black. Is there a setting to enable sharp black text with the UltraPrintPreviewDialog? Any suggestions? I have sample code, but it is derived from the sample at forum discussion http://forums.infragistics.com/forums/p/1237/11676.aspx#11676 Thanks, Stan
