885
Detecting column resize on mouseup event
Hi, based on your sample I am using grid mouseup event to open another dialog by clicking on grid column header, however i don't like column resize effecting same code. Any way to prevent this?
Thanks!
Current Code:
Private Sub Grid1_MouseUp(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles Grid1.MouseUp
Dim mouseupUIElement As UIElement = Grid1.DisplayLayout.UIElement.ElementFromPoint(New Point(e.X, e.Y))
Dim mouseupColumn As UltraGridColumn
Dim mouseupRow As UltraGridRow
Try
' retrieve the Column from the UIElement
mouseupColumn = mouseupUIElement.GetContext(GetType(UltraGridColumn))
' retrieve the Row from the UIElement, important to prevent pop-up on non header click
mouseupRow = mouseupUIElement.GetContext(GetType(UltraGridRow))
Catch
End Try
If Not mouseupColumn Is Nothing AndAlso mouseupRow Is Nothing Then
    Select Case mouseupColumn.Key
          Case "Blah"
                      Dim objFrm As New Form3
                      objFrm.ShowDialog(Me)
    End Select
End If
End Sub
