625
Column Chart - Color
I am plotting a column chart  I want to add different color to each column.
I am binding a dataset to the chart, my data is fetched as follows
Column1            colum2
10                       Active
20                      Pending
Please find attached an image, I want different color for Active column and Pending column
Can you please guide me, how to proceed with this
  • 5118
    There are several options to do this:
    1 -  You can set the color model scheme to use dynamically:
        myChart.ColorModel.ModelStyle = Infragistics.UltraChart.Shared.Styles.ColorModels.CustomLinear;
        myChart.ColorModel.CustomPalette = New Color[ { Color.Green, Color.Purple };
    In this case Active would be Green and Pending would be Purple.
    2 - You can  set the ModelStyle to CustomSkin and define a Collection of PEs (Paint Elements) and define 2 PEs and set them up with the appropriate colors.  Set the Skin.ApplyRowWise to False and you'll get the same effect.
     3 - You can get access to the underlying Primitives (FillSceneGraph event or ChartDrawItem) and modify the Paint Elements on the Primitives that represent the columns (Box Primitives) directly.
