185
UltraDateTimeEditor - Is this possible
 Hi All,
 I was wandering about one thing. In some case behaviour of UltraDateTimeEditor component is not so good. For example if I have something like this:
HH:m|m:ss
And if I start typing on place where is '|' value will not be changed. Only if I delete one or both numbers I can do change. Is possible to have behaviour as in .net datetimepicker? In that case if I click on minutes and just start typing minutes are changing with out any action before.
Thanks in advance!
  • 18495
    The UltraDateTimeEditor doesn't have that capability built in, but if you do what I did in the attached sample, you'll find it works the way you want.  The same technique can be used with the UltraMaskedEdit control.
    UltraDateTimeEditorTest.zip
