947
Memory Leak issue in group by row
when I use group-by-column feature on a column that had many different values (which will create many sub-rows), the application simply hung, and when I stopped, I got the following on the call stack.
And, another question is that even I did "SuspendSummaryUpdate()" on grid, does this get resume by default, or once I suspended, does it remain suspended?
(Top is the when I broke)
mscorlib.dll!System.Collections.ArrayList.Capacity.set(int value) + 0x3e bytes
mscorlib.dll!System.Collections.ArrayList.EnsureCapacity(int min) + 0x26 bytes
mscorlib.dll!System.Collections.ArrayList.Add(object value = "Subproduction9") + 0x1e bytes
Infragistics2.Win.UltraWinCalcManager.v8.2.dll!PerCederberg.Grammatica.Parser.RecursiveDescentParser.CallStack.Push(string name = "Subproduction9", int value = 1) + 0x20 bytes
  Infragistics2.Win.UltraWinCalcManager.v8.2.dll!PerCederberg.Grammatica.Parser.RecursiveDescentParser.FindLookAhead(PerCederberg.Grammatica.Parser.ProductionPattern pattern = {PerCederberg.Grammatica.Parser.ProductionPattern}, int length = 1, PerCederberg.Grammatica.Parser.RecursiveDescentParser.CallStack stack = {PerCederberg.Grammatica.Parser.RecursiveDescentParser.CallStack}, PerCederberg.Grammatica.Parser.LookAheadSet filter = null) + 0xa1 bytes
  Infragistics2.Win.UltraWinCalcManager.v8.2.dll!PerCederberg.Grammatica.Parser.RecursiveDescentParser.FindLookAhead(PerCederberg.Grammatica.Parser.ProductionPatternElement elem = {PerCederberg.Grammatica.Parser.ProductionPatternElement}, int length = 1, int dummy = 0, PerCederberg.Grammatica.Parser.RecursiveDescentParser.CallStack stack = {PerCederberg.Grammatica.Parser.RecursiveDescentParser.CallStack}, PerCederberg.Grammatica.Parser.LookAheadSet filter = null) + 0xa0 bytes
...(Many of the above)...
Infragistics2.Win.UltraWinCalcManager.v8.2.dll!Infragistics.Win.CalcEngine.UCCompilation.Parse(Infragistics.Win.CalcEngine.IUltraCalcReference baseReference = {Infragistics.Win.UltraWinGrid.GroupLevelSummarySettingsReference}, string formula = "SUM( [StartExpN] )") + 0xad bytes
  Infragistics2.Win.UltraWinCalcManager.v8.2.dll!Infragistics.Win.CalcEngine.UltraCalcFormula.Compile(Infragistics.Win.CalcEngine.IUltraCalcReference formulaReference = {Infragistics.Win.UltraWinGrid.GroupLevelSummarySettingsReference}, string formula = "SUM( [StartExpN] )") + 0x63 bytes
  Infragistics2.Win.UltraWinCalcManager.v8.2.dll!Infragistics.Win.CalcEngine.UltraCalcFormula.UltraCalcFormula(Infragistics.Win.CalcEngine.IUltraCalcReference formulaReference = {Infragistics.Win.UltraWinGrid.GroupLevelSummarySettingsReference}, string formula = "SUM( [StartExpN] )", Infragistics.Win.CalcEngine.UltraCalcFunctionFactory functionFactory = {Infragistics.Win.CalcEngine.UltraCalcFunctionFactory}) + 0x5f bytes
  Infragistics2.Win.UltraWinCalcManager.v8.2.dll!Infragistics.Win.UltraWinCalcManager.UltraCalcManager.Infragistics.Win.CalcEngine.IUltraCalcManager.CompileFormula(Infragistics.Win.CalcEngine.IUltraCalcReference baseReference = {Infragistics.Win.UltraWinGrid.GroupLevelSummarySettingsReference}, string formula = "SUM( [StartExpN] )", bool suppressSyntaxErrorEvent = false) + 0xbe bytes
Infragistics2.Win.UltraWinGrid.v8.2.dll!Infragistics.Win.UltraWinGrid.RowsCollection.GetRowWithListIndex(int listIndex = 48) + 0x20 bytes
  Infragistics2.Win.UltraWinGrid.v8.2.dll!Infragistics.Win.UltraWinGrid.UltraGridBand.DataSource_ItemChanged(object sender = {System.Windows.Forms.CurrencyManager}, System.Windows.Forms.ItemChangedEventArgs ea = {Index = 48}) + 0x38a bytes
  System.Windows.Forms.dll!System.Windows.Forms.CurrencyManager.OnItemChanged(System.Windows.Forms.ItemChangedEventArgs e) + 0x67 bytes
  System.Windows.Forms.dll!System.Windows.Forms.CurrencyManager.List_ListChanged(object sender, System.ComponentModel.ListChangedEventArgs e) + 0x3cf bytes
  [Native to Managed Transition]
  [Managed to Native Transition]
  System.Windows.Forms.dll!System.Windows.Forms.BindingSource.OnListChanged(System.ComponentModel.ListChangedEventArgs e) + 0x7b bytes
  System.Windows.Forms.dll!System.Windows.Forms.BindingSource.InnerList_ListChanged(object sender, System.ComponentModel.ListChangedEventArgs e) + 0x2e bytes
  • 469
    Hi tboy79,
    I am seeing what looks like memory leaks from Infragistics Grid and the PerCederberg components are listed too so think it might be related to your post. Did you manage to get this logged as as an issue and fixed? If so, can you remember what the fixed version was? I am using winforms 9.2
    Javier
  • 37774
    It's not really possible to determine the cause of this issue on the forums, so what you should probably do is submit the issue to Developer Support along with a sample demonstrating the issue so that they can look into it, or see if the issue has already been addressed.  One thing to try before you do this is to make sure that you have applied the latest hotfix.
    As for your question about SuspendSummaryUpdate(), they will not be resumed until a call to ResumeSummaryUpdates is made.
    -Matt
