Thanks.
My guess is that if the error message is not specific, then you are encountering an unanticipated error. Can you duplicate this behavior in a small sample project? If so, you should Submit an incident to Infragistics Developer Support so they can check it out.
Hello. I use MultiCellOperations and want to ask one thing.
Sometimes, when i try to copy(ctrl+c) cell value message box appears
"Error performing Copy operation. Further information: Requested clipboard operation did not succeed."
Could you tell me why "clipboard operation did not succeed" ? Any reason for it?
This message appears in a random way.
Thanks. Waiting for reply.
Nope, you are right, if you want to customize it like that you need to code it yourself.
