455
Combo value not saving when setting the selected row
I have a combo box filled with data the user clicks a button and a form is displayed that allows them to select a record that exists in the combo by looking at a lot more data to make there selection. I pass back the ID which is set to the ValueMeber of the combo. On the return I loop through the combo rows until I find the matching ID and I then set the selected row to the row object. All this works fine. My problem is that when I try to save my data the ValueMember isn't being saved.
I'm using VS2005 and I have the combo bound to a binding source, and all this is set correctly because if I make the selection by either keying in the value or selecting it in the dropdown everything works as it should. The only problem I am having is figuring out why the value isn't saving when I set the selected row in code.
Here is how I am setting the selected row.
foreach (Infragistics.Win.UltraWinGrid.UltraGridRow comboRow in icboContact.Rows){if ((Int32)comboRow.Cells["contact_id"].Value == someID){
icboContact.SelectedRow = comboRow;
break;}}
I don't understand why this isn't working. I know this has to be something with the combo not firing an edit event or something of that nature since I'm setting this in code, because if I make a selection in the combo in the normal way then the valueMember is saved correctly.
What am I missing? Thanks for any help.
Kris
