345
Unable to save DockManager settings
Hi, I am using ultraDockManager and would like to be able to restore to the last layout. . when I set the ultraDockManager.SaveSettings property to True and compile, the setting has reverted to false. . when I programmatically call LoadFromXML and SaveToXML, the layout is not restored (though the XML is written through the save). Clearly there is something I am missing. Any help much appreciated. thx l.
  • 44743
    I have never seen this property revert back to False after being set to True. Also, I am a bit surprised that the layout was not restored correctly. Are you doing things in the correct order (are you calling LoadFromXML after InitializeComponent has completed)? If so, I would recommend submitting a sample demonstrating the issue to the support group so it can be investigated: http://ko.infragistics.com/gethelp.
