In my ultragrid I have a column hooked to an UltraDropDown to show a meaningful description of the underling value.
DataSource of the UltraDropDown:
Value - DescriptionM_Key1 - "Description of Master Key 1"M_Key2 - "Description of Master Key 2"M_Key3 - "Description of Master Key 3"
DataSource of the Ultragrid (I report only the data in the UltraDropDown's column)
UddColumn's DataM_Key1 ----> On screen UltraDropDown correctly show the text "Description of Master Key 1"m_key2 -----> On screen UltraDropDown show the text "m_key2" instead of "Description of Master Key 2"
Why does the UltraDropDown show the correct description text only if the ValueMember have the exact same case?How can I make the UltraDropDown case-insensitive, so that it will show the correct description even when the case of the ValueMember text are different?I don't have control over the data underling the ultragrid because this data come from the DB, and I don't know the characters "case" that have been used for data entry.
Thanks,Max
Hey, I have the same issue!
I was looking for a property or so that would make the dropdownlist ValueMember as case insensitive instead of case sensitive. does it exist?
Hello Max,
A possible approach to achieve this would be to use an event like 'BeforeExitEditMode' of the grid and to check for string equality using, for example, the 'ToLower()' method. Something similar to the following code sample:
private void ultraGrid1_BeforeExitEditMode(object sender, BeforeExitEditModeEventArgs e) { foreach (UltraGridRow row in ultraDropDown1.Rows) { if (ultraGrid1.ActiveCell.Text.ToLower() == row.Cells[0].Value.ToString().ToLower() && ultraGrid1.ActiveCell.Text != "") { ultraGrid1.ActiveCell.Value = row.Cells[1].Text; } } }
Please feel free to let me know if I misunderstood you or if you have any other questions.
