150
Can't switch tabs in wrapped UltraTabControl
I am wrapping UltraTabControl by dropping it onto UserControl. So  MyTabControl inherits from UserControl and there is
private Infragistics.Win.UltraWinTabControl.UltraTabControl ultraTabControl1;     in  mytabcontrol.designer.cs   file.
In this case at design time   it is not possible to switch tabs, add controls to tabs or implement any UI actions on the UktraTabControl.
In order to "deliver" Click to the UltraTabControl  I  create   MyDesigner that inherits from ParentControlDesigner and attach it to the MyTabControl.
Then, I override GetHitTest(), check if my mouse click happens withing tab rectangle and return true, which suppose to "deliver" Click to the UltraTabControl.
This approach does Not work with UltraTabControl, but works with Windows TabControl.
How do I do that for UltraTabControl?
Is there any other approach to get UI functionality at design time for wrapped UltraTabControl ?
Thank you
