In VS2005, when I try to dock a window to a pane, it shows some arrows (not sure what it should be called, maybe dock indicator) to help me decide which pane the window will go to. Please see this image as an example:http://www.saraford.members.winisp.net/images/ToolWindowDockingWeb.jpgHowever, in my implementation using UltaDockManager, there is no arrows shown while docking.Is there any property on the UltraDockManager to enable this?
Thanks.
Its not working, even in ultradockmanager 11.2.
I have set these all attribute and tried different combinations, but all in vain.
Have you found any solution to show the indicators.
