585
Mimicking the UltraGridColumnChooser's drag & drop ability
(Infragistics 2008 Vol. 3, CLR 2.0)
I'm building my own column chooser based on an UltraTree to replace the UltraGridColumnChooser. Getting the checkboxes to behave the same wasn't an issue, but I haven't found a way to drag a column from the tree to the grid and have it accept it.
In my tree, each UltraTreeNode has a Tag with the following struct:
    Private Structure DraggableGridColumn
        Public NodeKey As String
        Public NodeName As String
        Public ParentKey As String
        Public Column As UltraGridColumn
    End Structure
I then have an event as follows:
    Private Sub columnsTree_SelectionDragStart(ByVal sender As Object, ByVal e As System.EventArgs) Handles columnsTree.SelectionDragStart
        If columnsTree.SelectedNodes.Count <> 1 Then
            Return
        End If
        If Not TypeOf columnsTree.SelectedNodes(0).Tag Is DraggableGridColumn Then
            Return
        End If
        Dim column As UltraGridColumn = CType(columnsTree.SelectedNodes(0).Tag, DraggableGridColumn).Column
        columnsTree.DoDragDrop(column, DragDropEffects.All)
    End Sub
In the DoDragDrop call, neither column (of type UltraGridColumn) nor column.Header (of type ColumnHeader) get accepted by the grid. I assume I'm sending the wrong type, and/or that the grid expects a special struct with some additional information. Unfortunately, I've also failed to catch an event (both on the column chooser side as well as on the grid side) where Infragistics's normal column chooser does this properly; the normal drag & drop events never seem to fire.
