543
WinGrid cell validation
in my application I use a WinGrid to collect informations about a set of properties. The grid has two columns, one for the name of the properties, and the other for the values. So, each row in the grid represents a single property. Depending on property type and attributes, the cell holding value has a particular style and editor (ColumnStyle.Double, ColumnStyle.Date, ColumnStyle.DropDown, ...).
I would like to set a max length for text-type properties, but unfortunately it seems to be a column-only attribute. So I have to make a little validation on my fields, but I can't find a pretty solution to the following questions:
- which is the best event I can use to trap all changes to my value fields? Now I'm using 'BeforeCellUpdate', but it doesn't allow me to force the cursor to remain in the not-validating cell. So I tried to use 'BeforeExitEditMode', but it doesn't fire on DropDown fields...
- how can I replace the value that doesn't validate (value too long, for example) with a correct value (the same value, trimmed, for example), in which event? I tried to set a new value to the cell in 'BeforeCellUpdate', but it raises an exception:
"Value property can not be assigned while BeforeCellUpdate event is in progress".
Please let me know if I'm missing something... :)
Thank you for your time,
Valentina
