130
Adding properties and methods to a cell derived from UltraGridCell?
Guys, can this be done:
I have some special functionality needed behind cells in a particular col. I think I need to build a custom cell derived from UltrGridCell and assign that as the celltype on a given column. I don't want to go as far as building a whole new CellEditor, implementing interfaces and all. Just some extra functionality behind the loading of data and entering/clicking into the cell... I do realize this might not be a trivial pursuit.
As tha data is loaded (in this case manually and not bound), I'd like to set custom properties on a cell.
eg: ultraGrid1.Rows[3].Cells[3].SpecialProperty = "special value";
As the user double-clicks or presses return in a given cell, call some custom method.
eg: ultraGrid1.ActiveCell.SpecialMethod("input");
 Maybe doing things in the AfterCellActivate event or ClickCell, DoubleClickCell and KeyDown events...
 Any advice would be great.
