I am using Infragistics UltraWinToolbars. In that toolbar, there are certain icons. There is a window containing this toolbar.
If i move another window over this, the background window's toolbar area becomes black.
It is like the portion of the foreground window covering the background window becomes black in color.
What to do to avoid this problem.
Please help me.
Hello.
I'm trying to fully understand the behavior you are encountering. When you cover a form which contains an UltraToolbarManager toolbar with another form, portions of the top-level ("covering") form are turning black? That is an interesting symptom. Perhaps the answers to the following questions could help us narrow down the cause.
If you have not done so already, you may want to consider contacting our Developer Support team so you can have a Developer Support Engineer dedicated to your issue.
Thanks,Chris
