80
Adding unbound columns at runtime
Hi, I'm trying to add a column in all bands of my grid, where I could place an icon of the row Status (validation issues)... I've set this code at OnInitializeLayout for each band in Me.DisplayLayout.Bands col = band.Columns.Add("colError",String.Empty) col.Width = 20 col.Hidden = False col.DataType = GetType(System.Drawing.Bitmap) col.Header.VisiblePosition = 0 next This works for all the bands where I'm not using "UseRowLayout".... in those columns (with UseRowLayout = true) the new column doesn't appear, though I'm sure its created in the init event (I traced it and it's there when init finishes) Is there anything special I must do to make that column appear in bands with UseRowLayout = true ?? Thanks in advance
  • 37774
    You might need to play around with setting the column's RowLayoutColumnInfo.OriginX to appear after the highest OriginX of the other columns; if you want it to appear earlier, you need to set its OriginX and then shift over the other columns.  Naturally this would be a lot easier at design-time since you could then use the designer to manipulate your layout and position your unbound column.
    -Matt
