930
Binding a manually defined Schema for Child bands
I've created a parent-child grid with a manually defined schema, so that I can control which fields are displayed for each band. My datasource is a Dataset with two tables that contain a parent-child relationship. When I bind the grid using the following:
ultragrid.SetDataBinding(ds, null, true);
...the manually defined schema only works for the parent band. The child band will continue to display all the fields in the child table. How do I get the grid to recognise the schema for the child band?
Ryan
