3555
Error: Trying to add a drop down in a row cell when in group by
When the grid is not groupby a column, the code below work.  However, when it’s group by a column, (row.Cells["BrandGeneric"].Text == string.Empty) will throw an error null reference exepction for the row object.
We are trying to add a valuelist for the cells in a column whethere the grid has a column in group by or not.
private void AddGenericBrandDropDown()
            UltraGridBand band = this.grdPricingDrugCurrentTherapyDosing.DisplayLayout.Bands[0];
            foreach (UltraGridRow row in grdPricingDrugCurrentTherapyDosing.Rows)
                if (row.Cells["BrandGeneric"].Text == string.Empty)
                    // Add dropdownlist to the empty cell
                    ValueList brandGeneric;
                    if (!band.Layout.ValueLists.Exists("BrandGeneric"))
                        brandGeneric = band.Layout.ValueLists.Add("BrandGeneric");
                        brandGeneric.ValueListItems.Add(1, "Brand");
                        brandGeneric.ValueListItems.Add(2, "Generic");
                    row.Cells["BrandGeneric"].ValueList = band.Layout.ValueLists["BrandGeneric"];
                else
                    // Not allow edit mode if the cell alread has a value
                    row.Cells["BrandGeneric"].Activation = Activation.NoEdit;
