I am iterating through a collection and adding nodes under a chosen Parent node. I am facing an ordering issue. The Collection has items in the order Item1, Item2, Item3. When I iterate through the collection and use destinationNode.Nodes.Add(Item), the items are added and displayed in the reverse order as Item3, Item2, Item1 under destination Node. How can I add it to tree Control and preserve the order in which the Items are loaded?.
Its a mistake on my part in loading the collection. Thanks for the reply.
Unless I misunderstood this, it sounds like the Override.SortType property is set to 'Descending'; you can suppress sorting by setting it to 'None'.
