2745
The ValueMember property of my WinCombo isn't accepting its value.
Hello!
The datasource of this  WinCombo is a dataTable that is generated from a query that  returns two fields that have the same name, due to a relationship between two tables. When I set this ValueMember property is says that *key not found*. I have tried with both the Column name it self and with TableName.ColumnName but none of these work. Any ideas?
If I use another column name in this datatable that is the only one of its kind it works perfectly....
Of course I can create this query in another way so that I only get one field of these...
Thanks for the help!
/Henrik
  • 2745
    Hello again!
    Thanks for the answer. I know that using the AS clause in my SQL statement as well as simply removing the duplicate field will solve the issue. But the reason I asked was that usually you get a unique identifier by using the TableName.FieldName but I couldn't get that to work here. My first column/field in my datatable was this ambiguous field of type *number* and when i looked for the column name using datatable.columns(0).columnname something it returned tablename.fieldname since it's represented in another column as well. For the fields that are unique, it only showed the field name straight off. so it made sence putting the tablename.fieldname as the valuemember...
    But now I know that I have to use a unique field as the ValueMember, and that the tablename.fieldname isn't really working...
    Thanks again!
    /Henrik
