I am trying to get all the nodes in my Win Tree Control as a TreeCollection. Just unable to figure out which member will return this to me. Also is there a way to get the number of levels within the Win Tree?. It would be ideal if there is a API which can take the level I pass to it and return me the nodes on that level as a TreeCollection. Let me know your thoughts. Thanks.
Look into this resource. I found it useful. The IterateNodes Subroutine might help you.
<http://help.infragistics.com/Help/NetAdvantage/NET/2007.3/CLR2.0/html/WinTree_Nodes_Overview.html>.
-Saravanan.
Just use recursion:
private List<Node> allnodes = new List<Node>();
foreach (Node ne in ultraTree.Nodes){ allnodes.Add(ne); if (ne.Nodes.Count > 0) WalkTree(allNodes, ne);}
private void WalkTree(List<Node> allnodes, Node parent){ foreach(Node n in parent.Nodes) { allNodes.Add(n); if (n.Nodes.Count > 0) WalkTree(allNodes, n); }}
I didn't run this or anything but something like this should work, not sure if its the easiest way or not. Or look up walking a tree in Google.
Is there an example somewhere on how to walk through the nodes? Thanks.
The Nodes in the WinTree are not stored in a single collection, you would need to walk through the nodes and their child nodes recursively to get all of them.
