Basically the grid is empty with Allow Add Row on the bottom turned on. All I need to know is how to activate the first cell of the AddRow and put it into edit mode.
Thanks!
You could do something like this:
this.ultraGrid1.Rows.TemplateAddRow.Activate(); this.ultraGrid1.ActiveRow.Cells[0].Activate(); this.ultraGrid1.PerformAction(UltraGridAction.EnterEditMode, false, false);
However, please note that you cannot set focus to a control inside the Form_Load event. So if you try this code in Form_Load, it will activate the first cell, but it will not go into edit mode.
To get around that, use the Form_Shown event. Or... you can use Form_Load and call this code using a BeginInvoke instead of directly in the event handler.
