505
quick advice needed on UltraDateTimeEditor format and maskinput
I have been using the Windows DateTimePicker to display a time only and allow the user to spin the time.
The key is to just have a line like ctrl.CustomFormat = "HH:mm".  The only problem with this is that I have to have a time present in the control at startup.  I'd prefer to have it blank until the user starts hitting the up/down buttons.
Can I use the UltraDateTimeEditor for this purpose?  I would think so, I have already started the process.  I am using a FormatString of hh:mm and a MaskInput of {time}. The Value, I leave blank. I have set the spin button style to "Always". All picked on designer.  However, I have a few minor issues:
1.  Can I get rid of the dropdown button?  I don't need it.
2. The spinning doesn't work quite like the DateTimePicker.  When you spin to 12 (on the hours for example) it stops rather than cyle to 1. Is there a way to duplicate the behaviro
3. With the Value not set, it displays as blank.  That's fine (and exactly what I want!), but when you hit the spin button, only the hours part comes up. Then you have to do hours minutes and am/pm. It would be nicer if the first time the spin button was hit, it went straight to some time (like 08:00 AM).  Can I do this?
4. When you're not editing the control, it doesn't display the AM or PM. I assume the formatstring can be modified to show this?
Andrew
