I'm trying to have a decimal value displayed as a percentage. So, if my value is .75 - I'd like to see 75% on the screen. If my value is .7545 - I'd want to see 75.45%
I'm not sure what the best way to accomplish this is - I am trying to use the InputMask on the column but I'm having trouble building an InputMask that does what I want. Could anyone help me out or point me in a new direction?
What you're looking for is the Format property of the column object. Set this to "p", which is the standard .NET format string to parse numeric data into a percernt (including translating ".7545" to "75.45%").
The Format property applies when cells are not in edit mode. There is no InputMask property to achieve the same result while in edit mode. I believe you'd need to write a DataFilter if you want to see a value of "75.45%" when either in or out of edit mode, and to store that value as ".7545" in the underlying data.
