Hi
I want to add icons to my items during runtime. I set the imagelists (Large- and small)of the listview in the init-function of my form.
When I created new items to and I do assign the image for it.
In the LV now online an empty space appears where the icon normally is located.
Whats wrong?
Kindly regards
Chris
I believe some of them can be extracted from system DLL's, i.e., user32, shell32, etc.
It is difficult to speculate about what the problem might be without having a look at the code. You state that an "empty space appears", which could indicate that the image is corrupt or completely transparent.
The following code sample demonstrates the correct approach; you could possibly compare this to your code and determine what is going wrong:
this.listView.View = UltraListViewStyle.Details;this.listView.ViewSettingsDetails.ImageList = this.imageList1;
UltraListViewItem item = this.listView.Items.Add( null, "Test" );
// Assign the first member of the ImageList's Images collectionitem.Appearance.Image = 0;
If this doesn't help, you might want to post a small code sample that demonstrates the problem, or report the issue via the web support form so that you can provide a test project that demonstrates the problem.
