105
How can I make event UltraWinGrid, When active cell's key code is 'Enter' then automatically invoke AfterCellUpdate event?
I want to make validate code in AfterCellUpdate event and When user input 'Enter' key then KeyDown event catch it, purform AfterCellUpdate event.
This is code.
        private void UltraWInGrid_KeyDown(object sender, KeyEventArgs e)
            if (e.KeyCode == Keys.Enter)
                 //Here, I want to invoke AfterCellUpdate event
When user input some keys on active cell and input 'Enter' key or click other cell, I want to handle with same validation.
What is best way? is there other good way to validate those case?
  • 69832
    Suggested Answer
    What you might want to consider is, rather than actually raising the event, you could simply call the event handler method directly.
    Example:
    this.ultraGrid.KeyDown += new KeyEventHandler(ultraGrid_KeyDown);
    void ultraGrid_KeyDown(object sender, KeyEventArgs e)
        if ( e.KeyData == Keys.Enter )
            UltraGrid grid = sender as UltraGrid;
            UltraGridCell activeCell = grid.ActiveCell;
            if ( activeCell != null )
                CellEventArgs args = new CellEventArgs( activeCell );
                this.grid_AfterCellUpdate( grid, args );
    void grid_AfterCellUpdate(object sender, CellEventArgs e)
