Using the .Height property has no effect so I suspect there is some other property to allow it?
Yes setting the row height =40 is working making height =10 was not noticable thanks to both of you
especially mike
The Height property is the right one.
Like Michael Saltzman said you should override RowSizing property to Free.
ultraGrid1.DisplayLayout.Override.RowSizing = Infragistics.Win.UltraWinGrid.RowSizing.Free;
And set the Height of a chosen row as :
ultraGrid1.DisplayLayout.Rows[0].Height = 40;
(affected only the size of the first row in your ultraGrid).
Regards
Danko.
no effect no changes
in the image u will see that i want to make the row size bigger.Can u help in this
10 is smaller than the default MinRowHeight
in order to be set you have to do the following:
ultraGrid1.DisplayLayout.Override.MinRowHeight = 1;
After defining the Override to free i have defined the DefaultRowHeight = 10
but no change Why ? any other way to increase the height of all the row when it loads
