When a Grid is in CardView is there a way to control the height of the CardCaption? I am using the captionlines property but it does not seem to do what I want. I do not want any extra space below the caption. I've attached a screenshot from the Sample Explorer that will better explain what I am talking about... Looking at the code from the Sample Explorer, it seems that a common piece of code that from the different "Looks" is the "SupportThemes" property being set to false. Of course I am using 8.1.20081.2013 and this property is obsolete, and using the Property "UseOsThemes" has no effect...
Thanks for any help that you can give me...
I'm not sure I followed exactly what behavior you are expecting, but if you set the CaptionLines property to a value greater than one, the height of all headers must be increased, even if a particular header does not have a large enough caption to require more than one line. The reason for this is so that all cards have the same height, which is a necessary requirement for that particular layout.
Regarding SupportThemes/UseOsThemes: those properties have no bearing on this issue, and in fact are not applicable when the control is displaying in CardView mode, except for the scrollbar.
