535
click to end edit
When I click in the grid, but what would bee whitespace (ie to the bottom of the rows) it doesn't end editing the current cell.  How can I set it so it does?
Peter
  • 69832
    Suggested Answer
    You could programmatically end the edit mode session when a mouse button is pressed over a certain point of the control.
    Example:
    this.ultraGrid1.MouseDown += new MouseEventHandler(ultraGrid1_MouseDown);
    void ultraGrid1_MouseDown(object sender, MouseEventArgs e)
        UltraGrid grid = sender as UltraGrid;
        UIElement controlElement = grid.DisplayLayout.UIElement;
        UIElement elementAtPoint = controlElement != null ? controlElement.ElementFromPoint( e.Location ) : null;
        object context = elementAtPoint != null ? elementAtPoint.GetContext( typeof(UltraGridRow) ) : null;
        if ( (context is UltraGridRow) == false )
            UltraGridCell activeCell = grid.ActiveCell;
            if ( activeCell != null && activeCell.IsInEditMode )
                grid.PerformAction( UltraGridAction.ExitEditMode );
